Displays the counters for the number of packets bridged, switched, and snooped (Layer 2 statistics).
| vlan_name | Specifies a VLAN name. |
| vlan_list | Specifies a VLAN list of IDs. |
N/A.
None.
The following command displays the counters for the number of packets bridged, switched, and snooped (Layer 2 statistics) for the VLAN accounting:
show L2stats accounting
You can also enter the command as show l2stats. We use the uppercase letter here to avoid confusion with the numeral 1.This command was first available in ExtremeXOS 11.0.
The vlan_list variable was added in ExtremeXOS 16.1.
